Hi, I am new to Loki and Grafana and right now I am trying to install Loki on a windows 2022 server. I am testing Grafana Loki in a Docker Compose setup, but not seeing any data ingested into Grafana dashboard. But I can see the logs in my Docker Dekstop.
Can anyone tell me where the problem might be?
I followed the installation from the Loki Documentation.
This is the Docker Compose Config:
version: "3"
networks:
loki:
services:
loki:
image: grafana/loki:2.9.2
ports:
- "3100:3100"
command: -config.file=/etc/loki/local-config.yaml
networks:
- loki
promtail:
image: grafana/promtail:2.9.2
volumes:
- /var/log:/var/log
command: -config.file=/etc/promtail/config.yml
networks:
- loki
grafana:
environment:
- GF_PATHS_PROVISIONING=/etc/grafana/provisioning
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
entrypoint:
- sh
- -euc
mkdir -p /etc/grafana/provisioning/datasources
cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
apiVersion: 1
datasources:
- name: Loki
type: loki
access: proxy
orgId: 1
url: http://loki:3100
basicAuth: false
isDefault: true
version: 1
editable: false
EOF
/run.sh
image: grafana/grafana:latest
ports:
- "3000:3000"
networks:
- loki
and here is the database URL setting:
Grafana is successfully connecting to the data source “Loki”.
