I am using Grafana 8.4.3
I am trying to rename values sent by zabbix in the “zabbix problems” visualization
My goal is to remove "[MON-MQ] CHANNEL : " from the zabix value
This visualization does not have the value mapping option.
I’ve put a rename by Regex in the transformation tab with no success.
I’m quite sure of the regex I use but nothing happens…
Do you know in which fields the rename by regex is working?
As the zabbix returns a json, should I adapt the regex to parse the whole json in order to update the value?
Thanks for your help
Marc
