Hello there!
I am running Grafana 9.3.6. -
I want to rename the values of one of the columns of my rows using a RegEx expression.
But I also applied the transform “Labels to fields”.
- How are you trying to achieve it?
I tried usingRename by regextransformation but instead of renaming the values it renames the table header.
I also tried using Field override called Fields with name matching regex like this:
Fields with name matching regex: /./
Value mapping: ^Status do Serviço\s.(.) ABC
What happened?
It did not work. -
Rename my service names in the rows, it’s the values from the first column. -
I am currently trying:
Rename by regex after applying Labels to fields.
Override using Fields and value mappings using RegEx.
No errors received on the UI or related logs. -
Yes. I followed the same forums and instructions:
https://community.grafana.com/t/variable-with-value-mappings/24543/10
https://community.grafana.com/t/need-help-with-override-field-name-with-regex/73843
https://community.grafana.com/t/overrides-value-mappings-regex-not-working/55199
