Unable to pull data with JSON API
Hi all,
im having trouble just pulling data from this URL using the JSON API." https://api.open-meteo.com/v1/forecast?latitude=-26.342965&longitude=152.767959&hourly=temperature_2m&daily=temperature_2m_max,temperature_2m_min,et0_fao_evapotranspiration&timezone=Australia%2FSydney&forecast_days=1"
The data i want to pull is “temperature_2m_max”. Right now i have no clue what to all into the fields space
Have you tried the infinity plugin?
https://play.grafana.org/goto/Y_Uf65NSg?orgId=1
Yep it just worked Thank you!!
