Infinity-UQL Query on odd API JSON format
In Grafana Cloud - trying to call a weather API for historical temperatures to correlate with electrical usage data.
Using the grafanacloud-infinity data source to call the following API:
https://api.open-meteo.com/v1/forecast?latitude=52.52&longitude=13.41&hourly=temperature_2m&timezone=America%2FNew_York&past_days=31&forecast_days=3&timeformat=unixtime&wind_speed_unit=mph&temperature_unit=fahrenheit&precipitation_unit=inch
Output of the API
  "latitude": 52.52,
  "longitude": 13.419998,
  "generationtime_ms": 0.0957250595092773,
  "utc_offset_seconds": -14400,
  "timezone": "America/New_York",
  "timezone_abbreviation": "GMT-4",
  "elevation": 38,
  "hourly_units": {
    "time": "unixtime",
    "temperature_2m": "°F"
  "hourly": {
    "time": [1749787200, 1749790800, ETC, ETC],
     "temperature_2m": [54, 54.3, 57, ETC, ETC]
Trying to marry time and temperature into a time series using UQL.
Current Query calls the above api and uses the following UQL query which results in the error “error applying the UQL query”…
parse-json
| extend “data” = array_from_entries(‘Time’, $.hourly.time, ‘Temperature’, $.hourly.temperature_2m)
| mv-expand “data”
| project “Time” = unixtime_seconds_todatetime(“data.Time”), “Temperature”
Thoughts?
look at this
Thanks @yosiasz. I used the following which works:
parse-json
| jsonata “$map($zip($map($,function($v){$v.hourly.time}),$map($,function($v){$v.hourly.temperature_2m})), function($v){{‘Time’: $v[0], ‘Temperature’: $v[1]}})”
no need for the extra $zip, just adds more functions to maintain
