Unable to load SVG Image from url in canvas
“version”: “v10.3.0-64167 (89934b0884)”
I am using canvas plugin. I need to upload an external svg image as icon.
I can´t upload from device, because I use cloud version.
I am using the given field to load external URLs.
  • What happened?
The loading does not work, I get an empty image.
I expected to load successfully the image. If I try to set it as backround it works. I tried with different images; now I am trying with the following : svgsilh.com/svg_v2/1801287.svg
    N/A
No errors
I used grafana documentation.
Canvas | Grafana documentation
and prior topic : How can I use my own svg icons in Canvas plugin? - Grafana / Dashboards - Grafana Labs Community Forums
what do you see in your browser console, any errors?
Hello yosiasz, thanks for the reply.
Yes I just noticed I get the following error:
Access to fetch at ‘***********.svg’ from origin ‘https://datacenterhub.grafana.net’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource. If an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
But it seems to be impossible to handle it from Grafana, any suggestion?
If you search through this forum, you will see ngnix as a procy solution
Thanks I saw the solution you proposed. But it is something that can be done in grafana cloud as far as you know?
