Unable to define SQL query
Hello !
I just installed the Win64 version of Grafana. I defined a MySQL datasource. Connection test is successful.
I tried to create my first dashboard, adding a “Graph” panel. Also, when I go to the “Metrics” tab for the Graph, and select my MySQL datasource I can’t find where I can define the SQL query to be used.
Is there something I missed ? (I tried on different browsers, no difference)
Screenshot:
What browser version are you using ?
I tried:
  • Firefox ESR 52.3.0 (32-bit)
  • Chrome 60.0.3112.113 (64 bits)
  • Internet Explorer 11 (11.0.9600.18762CO)
bug in v4.5.0 , https://github.com/grafana/grafana/issues/9247 fixed in master, patch coming tomorrow
Thanks for this quick update. I will try with the new release as soon as it is available.
