I’m running into an issue accessing my Loki instance deployed on Azure Kubernetes Service (AKS). I’m using the Nginx Ingress controller to expose Loki externally, and Promtail is running within the cluster to ship logs.
Setup:
Platform: AKS
Service: Loki (standard stack, deployed via Helm/YAML)
Log Shipper: Promtail
Ingress Controller: Nginx Ingress
Ingress Config: No Auth
Domain: example.org (example, using my actual domain)
Problem:
My Ingress configuration seems partially correct. I have configured it to route traffic based on a specific path prefix:
I can successfully access https://example.org/rewardsy-loki/ready (returns 200 OK after Basic Auth). -
I can successfully access https://example.org/rewardsy-loki/metrics (returns Loki metrics after Basic Auth). -
Accessing https://example.org/ returns a 404 (This is somewhat expected as it doesn’t match my specific Ingress path rule). -
Accessing https://example.org/rewardsy-loki/ (the base path defined in the Ingress) also returns a 404 . This 404 seems to be coming from the Loki service itself after the Ingress routing and path rewrite. -
When trying to add Loki as a data source in Grafana using the URL https://example.org/rewardsy-loki (and providing the correct Basic Auth credentials configured in Grafana), I get the error: “Unable to connect with Loki. Please check the server logs for more details.” or sometimes a generic HTTP Error/Network Error.
Ingress Configuration:
Here’s my current Ingress resource YAML:
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/ssl-redirect: "true"
nginx.ingress.kubernetes.io/use-regex: "true"
nginx.ingress.kubernetes.io/rewrite-target: /$2
spec:
ingressClassName: nginx
rules:
- http:
paths:
- path: /rewardsy-loki(/|$)(.*)
pathType: Prefix
backend:
service:
port:
number: 3100
Logs :
[13/Apr/2025:10:50:42 +0000] "GET /rewardsy-loki/loki/api/v1/query?direction=backward&query=vector%281%29%2Bvector%281%29&time=4000000000 HTTP/1.1" 400 65 "-" "Grafana/10.4.15 AzureManagedGrafana/latest" 397 0.001 [loki-stack-loki-stack-3100] [] 10.244.5.47:3100 65 0.000 400 fecf5f34b97a88252b20fe8608bdf1f8
- I have verified the logs in the ingress-controller. It was saying this
SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking
But I dont have any SSL configured
- I tried to check the logs further and it was of no use.
