Grafana cloud, dunno, 8.5 maybe ? -
I have traces from tempo datasource with userd.id valorized tag
I can’t add the tag to the columns returned while building a chart -
What happened?
Can’t find a way to add a tag as a table column -
Being able to add a tag as a table column -
What configuration ? this is grafana cloud -
No -
No
