Can't show tag as column
Hi all, I’m new to Grafana and have what I think is a simple query, however, I just can’t work this out. the query works as expected in InfluxDB 2.7.1
Version Garafana 10.01
I’m trying to show the “sensor_id” in a column, the id is a tag and a string.
This is the query
from(bucket: "volt_sense")
  |> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
  |> filter(fn: (r) => r["level"] == "${q_level}")
  |> filter(fn: (r) => r["area"] == "${q_area}")
  |> filter(fn: (r) => r["location"] == "${q_location}")
  |> filter(fn: (r) => r["_field"] == "A0" or r["_field"] == "A1" or r["_field"] == "A2" or r["_field"] == "A3" )
  |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
  |> keep(columns: ["_time", "_value", "sensor_id","A0", "A1", "A2", "A3"])
  |> yield(name: "last")
However, I only get this as an output
I would have expected to see the “sensor_id” as one of my columns.
Any help would be greatly appreciated
Cheers
Hi @dirkeisner
What happens if you insert this line as an additional filter? (not sure about your actual tag name being used, so I guessed, but this is probably close)
|> filter(fn: (r) => r["sensor_id"] == "${sensor_id}")
Hi @dirkeisner ,
I found out that keep() function causes this issue because when I comment it out all tags are automatically displayed as columns in table. Also, when I use drop() function instead of keep() (in order to drop specific tags/columns) this issue does not occur.
However, you can work around this issue by using Grafana transformation “Labels to fields”:
This transformation changes time series results that include labels or tags into a table where each label keys and values are included in the table result. The labels can be displayed either as columns or as row values.
Best regards,
ldrascic
