Hi I have just added the newly updated google analytics plugins in Grafana 9.5.0 and followed all the procedure to configured the JWT tokens with Grafana, But after all the setup done when I am adding the parameters using the drop down Metrics, Time Dimensions and Dimensions there is no data showing in the graph and when I checked the log I found that it is throwing an error i.e.
logger=plugin.blackcowmoo-googleanalytics-datasource t=2023-06-06T07:06:00.900074353Z level=error msg=“Fail query” error=“failed to read query: error reading query: json: cannot unmarshal object into Go struct field QueryModel.dimensions of type string”
Can you please help me on this.
