Unable to access logs in Grafana dashboards using Loki datasource
  1. Please post inside a subcategory
  2. For questions and advice, please try to use the template below
  3. If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
  • What Grafana version - 10.0 and OS is Linux
I want access applications logs which has deployed on AKS cluster
    Created LOKI data source and able to access pod logs.
  • What happened?
    After sometime logs are not accessing.
    All the pod logs should be accessible.
  • Did you follow any online instructions? If so, what is the URL? yes
Hey, I’d start with below :
  • Is yor loki healthy ?
  • Is the agent i.e grafana agent / promtail healthy and sending all logs to loki ?
  • What error loki sends to grafana while querying logs via grafana ? try to check grafana logs ?
