I’ve installed grafana-loki and promtail to nable application log forwarding in my cluster. The following is my loki config file:
auth_enabled: false
common:
compactor_address: 'loki-backend'
path_prefix: /var/loki
replication_factor: 3
storage:
s3:
access_key_id: enterprise-logs
bucketnames: chunks
endpoint: logging-minio.shared-system.svc:9000
insecure: true
s3forcepathstyle: true
secret_access_key: supersecret
frontend:
scheduler_address: query-scheduler-discovery.shared-system.svc.cluster.local.:9095
frontend_worker:
index_gateway:
mode: ring
limits_config:
enforce_metric_name: false
max_cache_freshness_per_query: 10m
reject_old_samples: true
split_queries_by_interval: 15m
memberlist:
join_members:
- loki-memberlist
query_range:
align_queries_with_step: true
ruler:
storage:
s3:
bucketnames: ruler
type: s3
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: s3
schema: v12
store: boltdb-shipper
server:
grpc_listen_port: 9095
http_listen_port: 3100
storage_config:
hedging:
at: 250ms
max_per_second: 20
up_to: 3
table_manager:
retention_deletes_enabled: false
retention_period: 0
The following is my promtail config file:
# promtail-config.yaml
server:
# http_listen_address: 127.0.0.1
http_listen_port: 9080
grpc_listen_port: 0
scrape_configs:
- job_name: kubernetes-pods
kubernetes_sd_configs:
- namespaces: {}
- role: pod
pipeline_stages:
- docker: {}
relabel_configs:
- source_labels: ['__meta_kubernetes_pod_label_app']
target_label: 'app'
- source_labels: ['__meta_kubernetes_pod_label_namespace']
target_label: 'namespace'
- source_labels: ['__meta_kubernetes_pod_container_name']
target_label: 'container_name'
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/*log
# Add more scrape_configs as needed for different log sources
clients:
- url: http://loki-gateway.shared-system.svc.cluster.local:80/loki/api/v1/push
But as u can see below i can only see the loki pod logs and only the namespace where i’ve deployed all of this.
