UI Displaying incorrectly
Just completed my first install of grafana and noticed the UI is missing all the buttons/CSS. Is there something I missed in the install? Everything is functioning correctly. When I check a guide/tutorial, it is clear that I’m missing quite a lot here! Images attached.
Thanks
Looks like you installed a version old version
Ah. Yep, that was it. Thanks!
