v8.0.3
Windows -
Select a single value in a multi-value variable -
Clicking on it as I usually do -
What happened?
All values get selected instead -
Only that value would get selected -
This is what the variable definition looks like
* In fact it had “Include all options” selected, neither works
** I also tried adding quotes to the value part of the text, it doesn’t seem to make a difference
I click on one value:
All the values show as selected:
When I close the drop-down, it shows as if only the variable I had clicked was selected:
But the dashboard behaves as if all were selected (below is a panel that repeats based on that variable)
Couldn’t find anything similar to this
can you copy and paste the text inside Values separated by comma?
then someone in the forum can try and mock this up and troubleshoot it with you
also you might want to check out this issue:
Sorry about the delay. The values are
BOD : mg/L,COD : mg/L,TSS : mg/L,TN : mg/L,TKN : mg/L,NH4 : mg/L,TON : mg/L,NO3 : mg/L,NO2 : mg/L,NOx : mg/L,TP : mg/L,PO4 : mg/L,FOG-Extractable : mg/L,pH : -, Temperature : C,Conductivity : uS/cm,Alkalinity : mg/L,Cl2 : mg/L,DIN : mg/L,Fe : mg/L,InertSolids : mg/L,ORP : mg/L,PercentageInertSolids : %,S2 : mg/L,S2O3 : mg/L,Salinity : mg/L,SO4 : mg/L,Turbidity : mg/L,VSS : mg/L
Yes, this seems to be it. I was a bit surprised to learn that there are no plans to work on this, but guess I’ll have to wait.
Thanks!
