In newer versions of Grafana, especially from version 11.x, all selected values are displayed in the drop-down menu of the template variables. This behavior can lead to confusion with a large number of selected values. Does Grafana offer an option to change or deactivate this behavior?
Grafana Version 11.4.0 in docker -
In a long list of possible values for a dashboard variable, I don’t want to select the values that I need, but conversely deselect the ones that I don’t need. The reason for this is that the list of possible values is very long (several hundred entries). -
I would like to select all values in the dropdown filter by clicking on “Selected” and then deselect the values that I do not need. -
What happened?
If I select all possible values with “selected” as described, all selected values are displayed. Because there are so many, it becomes very confusing and I find it difficult to deselect individual values. -
As in old versions of Grafana (e.g. 10.0.3), I would like this preview of selected values not to be displayed.
