Two graphs with different axis scaling
Hello all,
I have already read some posts and am thrilled by the helpfulness of many users.
Thus, I would also like to turn to you.
I am trying to create a diagram in which on the one hand my power consumption is shown, which can also go into the negative because of a PV system, and on the other hand the solar curve, which in this case only has positive values.
How can I adjust the right axis so that the zero is also at the level of the zero of the consumption? So in principle move it upwards.
I hope that there is a simple solution.
Thank you very much!
I suggest you add an overide property to that column for axis centered zero.
May have to play around with adding for either both fields or just that one.
E.g. here is my column name ‘Flash Usage’ that is centered zero:
Thanks
