I asked similar question here: Variable namespace - are variables shared between dashboards? , but got no solution.
I checked json of my dashboard and I think I found why variable value differs from set in variable configuration.
I use variable $node_granPeriod value in maths to make it simple to change in future in various graphs.
Example:
Select before change: (granPeriod in minutes * 60 sec - here $ne_granPeriod has been set to 15)
SELECT ( ( sum("TermRecCntr") + sum("OrigRecCntr") ) / $ne_granPeriod * 60 ) FROM "..." WHERE ("hostname" =~ /^host1$/) AND $timeFilter GROUP BY time($ne_interval) fill(null)
Select after change (because granPeriod on NE has changed from 15 to 5): here $ne_granPeriod is set to 300 (5*60)
SELECT ( ( sum("TermRecCntr") + sum("OrigRecCntr") ) / $ne_granPeriod ) FROM "..." WHERE ("hostname" =~ /^host1$/) AND $timeFilter GROUP BY time($ne_interval) fill(null)
In json I can see new value (300) - changed from 15, but also still can see value 15 in section “current”
"current": {
"selected": true,
"text": "15", <<< old value
"value": "15" <<< old value
"hide": 2,
"label": null,
"name": "ne_granPeriod",
"options": [
"selected": true,
"text": "300", <<< new value
"value": "300" <<< new value
"query": "300",
"skipUrlSync": false,
"type": "constant"
To fix this (temporarily) I edit $ne_granPeriod definition - and click UPDATE without any changes. Grapsh are plot correctly from that moment but only till I refresh dashboard (even if I saved it first).
Could you tell me how to force dashboard to save new value in all fields in json? Do I use proper variable type (constant)?
BR
Mike
