I am using Grafana 9.1 and I have following target:
In an InfluxDB time series, I have the electrical power consumption per hour.
I would like to compare the consumption per hour of the last 24 four hours with the previous 24 hours in one single panel, as bar graphs.
How can I achieve that? Relative time and time shift can only be chosen once per panel.
With the equry editor, I did not get a result. With a query experession, using InfluxQL, I got at least the two bar graphs show, but still an after another, not overlapping:
Have you explored using Grafana’s dashboard time range settings to compare two different time periods within the same panel? How are you managing the time range in your queries?
