Two data-metrics on one graph
Im creating new visualization of our AWS cloud env.
I want to add two sets of data onto one panel of type graph. Im adding both sets (A and B) without any problems; when I disable one set, the other remains on (and thus visible), so its working as expected.
But…
There is not (at least to my knowledge) easy way to modify visual representation of set B. Only set A can be modified (as of visuals like line-width etc).
Anyone know how to change visual representation of set B?
Hello dev11! You can modify visual representation of set B with series overrides. You can learn more here: Visualizations | Grafana documentation.
Also, see the image below as example:
Thank you very much for your reply. It is what I needed.
