Ubuntu 22.04.5 LTS x86_64 and Grafana free tier? -
Trying to show geoIP2 from nginx from visitor request to the grafana nginx dashboard where it shows where the user IP address is located based on GeoLite2 Country -
i am trying to make nginx 1.18.0 support GeoLite2 Country -
What happened?
I have tried recompiling nginx, ver 1.27.2 but i was on 1.18.0 so i grabbed the wrong source file and iv tried recompiling for GeoIP work alongside -
that the GeoLite2 Country nginx model would work with nginx 1.18.0 -
log_format json_analytics escape=json '{'
'"msec": "$msec", ' # request unixtime in seconds with a milliseconds resolution
'"connection": "$connection", ' # connection serial number
'"connection_requests": "$connection_requests", ' # number of requests made in connection
'"pid": "$pid", ' # process pid
'"request_id": "$request_id", ' # the unique request id
'"request_length": "$request_length", ' # request length (including headers and body)
'"remote_addr": "$remote_addr", ' # client IP
'"remote_user": "$remote_user", ' # client HTTP username
'"remote_port": "$remote_port", ' # client port
'"time_local": "$time_local", '
'"time_iso8601": "$time_iso8601", ' # local time in the ISO 8601 standard format
'"request": "$request", ' # full path no arguments if the request
'"request_uri": "$request_uri", ' # full path and arguments if the request
'"args": "$args", ' # args
'"status": "$status", ' # response status code
'"body_bytes_sent": "$body_bytes_sent", ' # the number of body bytes exclude headers sent to a client
'"bytes_sent": "$bytes_sent", ' # the number of bytes sent to a client
'"http_referer": "$http_referer", ' # HTTP referer
'"http_user_agent": "$http_user_agent", ' # user agent
'"http_x_forwarded_for": "$http_x_forwarded_for", ' # http_x_forwarded_for
'"http_host": "$http_host", ' # the request Host: header
'"server_name": "$server_name", ' # the name of the vhost serving the request
'"request_time": "$request_time", ' # request processing time in seconds with msec resolution
'"upstream": "$upstream_addr", ' # upstream backend server for proxied requests
'"upstream_connect_time": "$upstream_connect_time", ' # upstream handshake time incl. TLS
'"upstream_header_time": "$upstream_header_time", ' # time spent receiving upstream headers
'"upstream_response_time": "$upstream_response_time", ' # time spent receiving upstream body
'"upstream_response_length": "$upstream_response_length", ' # upstream response length
'"upstream_cache_status": "$upstream_cache_status", ' # cache HIT/MISS where applicable
'"ssl_protocol": "$ssl_protocol", ' # TLS protocol
'"ssl_cipher": "$ssl_cipher", ' # TLS cipher
'"scheme": "$scheme", ' # http or https
'"request_method": "$request_method", ' # request method
'"server_protocol": "$server_protocol", ' # request protocol, like HTTP/1.1 or HTTP/2.0
'"pipe": "$pipe", ' # "p" if request was pipelined, "." otherwise
'"gzip_ratio": "$gzip_ratio", '
'"geoip_country_code": "$geoip_country_code"'
geoip_country /etc/nginx/GeoLite2-Country.mmdb;
# $geoip_country_code default=US source=$remote_addr country iso_code;
access_log /var/log/nginx/json_access.log json_analytics;
I’m mostly having issues with
had to disable
# geoip_country /etc/nginx/GeoLite2-Country.mmdb;
# '"geoip_country_code": "$geoip_country_code"'
for nginx to work again disabling the GeoLite2 module since i keep being stuck in a loop where if i try to fix it it will spit out an error.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
when i had it enabled, i did see an error in the Grafana nginx console about{being broken but i just have both - Did you follow any online instructions? If so, what is the URL?
I did try theNginx integration for Grafana Cloudpage where it said on how to configure the block until i got to the GeoIP2 module snippet where that’s where all the issues started.
Install GeoIP for Nginx · GitHub
GitHub - leev/ngx_http_geoip2_module: Nginx GeoIP2 module
everything worked fine until iv used the wrong nginx ver. right now without geoip it looks fine but whenever i try to setup geoip i end in a loop where i see
nginx: [emerg] unknown directive "geoip_country" in /etc/nginx/nginx.conf:109
nginx: configuration file /etc/nginx/nginx.conf test failed
in my nginx config. i want to personally thank Garrett T for trying to help me trying to get GeoLite2 Country to work on nginx (in a ticket).
My grafana-server ver is Version 11.2.2 (commit: c47b921ef40c0c411e9bad2cac05eb6c540c0979, branch: HEAD)
My alloy randomly spikes up to 40% then back down to %2 randomly, idk if it’s the hetrixtools agent doing that but yeah
