Trying to add openweather api: Error 401
i`m using Inifnity to add openweather api, but pop up 401 401 unauthorized.
That i do is add source Infinity and in URL section i put the API: http://api.openweathermap.org/data/2.5/weather?q=London&appid={API KEY}, when i click save its says “Data Source is working. No checks performed” but when i trying to create dashboard and put url in URL section shows 401 Unauthorized.
hi @divanovataro
Are you able to hit this endpoint using curl? I’m geussing that when you do you have to pass your authentication token in the request. I don’t know about infinity but the JSON API plugin is awesome and allows you to add headers to your JSON request. I would explore that.
Or, first get this working as a simple cURL request from the command line and then match that in the plugin.
