Troubleshooting With Grafana Using Linux and Process Top dashboards
I know a lot of questions are put here in how to use Grafana for system administration so I will give an example where using two dashboards to troubleshoot a CPU resource issue
I was informed of a peak in CPU usage on a server and asked to investigate. Looking at the Linux dashboard I pinpointed the time and dragged in for a deeper look:
After finding the time of the event I then copied the time range and moved on to the Process Top dashboard. I then applied the time range copied from the Linux dashboard:
I clicked on the CPU usage to order by biggest user:
As we can see, mysqld was the CPU hog. With this in mind now, I investigated MySQL for any issues that were going on with the server.
For those wanting to use the Process Top dashboard it is 3387. This uses InfluxDB/Telegraf. In your Telegraph configuration make sure it is set the [[inputs.procstat]] with the one line:
pattern = “.*”
I hope this helps out someone that might be looking for a needle in a haystack.
Hi @jasonmallory,
Thanks for creating this post and appreciate your efforts in contributing to the community. :+1:
Can you also share the link to that Top process dashboard so that it becomes more visible?
Sure here it is - Process "Top" | Grafana Labs
