Transpose a table in Grafana
I have the table below
|Field|Total|
|UNICAST Total|1179|
|MULTICAST Total|7107|
|UNICAST Failed|107|
|MULTICAST Failed|754|
How do I transpose it using transform or other to the below?
|Field|UNICAST Total|MULTICAST Total|UNICAST Failed|MULTICAST Failed|
|Total|1179|7107|107|754|
Hi @hatman,
What datasource are you using, and what version of grafana?
Can you include any screenshots of your table?
Hi @anon70503803 pic attached of the table i have.
data source is elastic search.
version is 7.5.7.
tks, appreciate your reply.
ok, great, thanks.
Can I ask: why are you trying to transform this data? In other words, what are you trying to achieve and why?
I ask because Grafana’s data frame model is columnar oriented, and was originally designed to visualize time-series data.
to answer your question on what and why, I wanted to create a table like the transposed in the pic so I could easily create a success rate in the columns.
Maybe I am not using grafana as it was meant. tks I will look into the data frames.
not necessarily. Grafana can support non time-series data like this, to varying degrees. What are your elastic queries, out of interest?
I’d also take a look at all these example dashboards built using Elastic queries.
eventType:DeviceRequestResponseEvent
AND (_exists_:payload.cattle.name)
AND farmId:*
AND payload.deviceRequestResponseEvent.payloadType:COMMAND_REQUEST_TYPE
example query, the query is just count of certain criteria. the above would be query A and then I would have another queryB …query N and then just calculate on them accordingly using transforms in grafana.
Ok. I would also suggest checking out the new Bar Chart that is getting released with Grafana 8. It is designed to handle non-time series data:
https://play.grafana.org/d/YI95GyqMz/1-new-features-in-v8-0?orgId=1&viewPanel=73&editPanel=73
I notice that now we have a ‘Transpose’ transformation since Transformations: Add 'transpose' transform by jmdane · Pull Request #88963 · grafana/grafana · GitHub (2024-8).
