I notice when using the “Add Field from Calculation” transformation on the graph panel that it does not connect between points even when you turn the setting on. I understand it is still in beta, but wanted to provide feedback. Does anyone know of a work around for this?
Hey, I have a similiar issue but worst. I have metrics with 1m interval. It shows normal without transform. But when I add a transform calculated field (whatever it is), the metrics disappear. I’m adding with and without transform rule screenshots by same date and data.
It works normal if I choose > 3 hours by the way.
Without Transform Rule,
With Transform rule added,
I need to know that do I miss something or is this a known issue?
Thanks all, regards.
edt: Grafana vers: 7.0.3
