"Problems" with the transformation "Add field from calculation" (v10.2.2)
Problems with the transformation “Add field from calculation” since version v.10.2.2
In “Reduce row” mode, there is no longer a line break under the operations.
Here an example:
Does anyone else have the problem or is it on my side?
Jo
Hello, I encountered the same issue on version V10.2.3. Have you resolved this issue?
Hello tzkone,
no, no reaction on this topic.
The same with 10.2.3 as you have also noticed
I also noticed it and just created a Github issue.
Still have the same problem here
the same with the latest stable version.
@joachimschiewek Just completed today. :smiley:
