Dear Community,
I am using Grafana 11.6.
I need your support to convert a json file in a readable set of data for the XY chart.
Here the file I get:
“2023-10-10T00-00-02 UTC”: {
“x”: [0, 2, 4],
“y”: [27.11, 26.77, 26.90]
“item_type”: “OTS3TemperatureData”
for each x and Y there are thousands of points.
I need to convert to a file where time is duplicated as timestamp, x as position column and y as measured value column.
Thanks for supporting
Step 1: Create input.json file and past your json
Step 2: using python script conver the json to csv (this format ready by xy chart easily)
import json
import csv
from datetime import datetime
# Path to your input file
input_path = r"C:\Users\Dell\Desktop\script\input.json"
output_path = r"C:\Users\Dell\Desktop\script\output.csv"
# Load JSON file
with open(input_path, "r") as f:
data = json.load(f)
# Write to CSV file
with open(output_path, "w", newline="") as csvfile:
writer = csv.writer(csvfile)
writer.writerow(["timestamp", "position", "measured_value"]) # header row
for ts, values in data.items():
if ts == "item_type":
continue # ignore metadata
# Format timestamp: "2023-10-10T00-00-02 UTC" → "2023-10-10T00:00:02Z"
dt = datetime.strptime(ts.split(" ")[0], "%Y-%m-%dT%H-%M-%S")
formatted_time = dt.strftime("%Y-%m-%dT%H:%M:%SZ")
# Extract x and y values
x_vals = values["x"]
y_vals = values["y"]
# Write rows
for x, y in zip(x_vals, y_vals):
writer.writerow([formatted_time, x, y])
print("✅ Done! CSV saved to output.csv")
Step 3:
install and add datasource
note : while adding datasour it will give error then you can go to folder where python script, input.json, and output.csv are present run this command to adding datasource
Step 4: after adding datasource add transformation
final output:
I appreciate the detailed answer. My issue, I apologize if I was not clear, is that I can rely only on transformation inside Grafana, maybe using JSONata or the Transformations.
I am currently struggling with JSONata
you can use jsonata to carve up the data the way you want it within grafana using infinity plugin
https://try.jsonata.org/JuGYwxHJ3
Many thanks,
but for whatever reason it doesn’t work.
checkout my jsonata and compare it to yours. few things missing there.
Many thanks!
As you said there were some missing “” and some hidden character.
I’ve appreciated your help
