Transform - Fill missing time series points
Hi All,
I have data coming from a narrow Timestream database, the timestamps for the different series are not synchronised - as they are only sent when the data has changed more than a set amount.
I need to sum two of the series “Series A” and “Series B”.
To do this I have been trying to use the “Add field from calculation” → “Reduce Row” → “Last *” function as I believed this would fill in the null values with the last reading.
However it doesn’t seem to do anything to my data.
Does anyone know what I have missed?
Hi, AFAIK Add field from calculation will take default 0 if the field is empty (you can see that in your Total column), so if your case is just sum A and B in each timestamp - it’s just it.
UNLESS what you want is to have two numbers as a result - sum of all values of series A and sum of all values of series B (which I’ve thought about just now), you can then use Reduce transformation (something like that) that will reduce each column with a certain calculation (use total for your case).
Sorry for the slow reply, that seems to match what I have found. The closest effect I have found so far is (mis)using a centred mean with a small window, however this will only fill in short gaps.
Is there any way to fill downwards using the last value in a transformation or another way to calculate the sum using the last value of each column?
Maybe try using the new (still in private preview) Transform by SQL Expressions?
