Transform data using Regular Expression
First of all, I am using Grafana version 8.0.5. I have a set of data looking like that:
/v2/ports/PF-12345
/v2/services/cloud/PF-67891
/v2/services/cloud/connections/PF-123467
I am trying to modify this data set like below (basically removing v2 and the ID at the end of the URL.
ports
services/cloud
I tried to use the Rename by regex under the Transform tab in my Panel but I am not having any success, I think it must be somewhere else.
Here is a regular expression I worked on regex101: build, test, and debug regex
Thanks for your help!
Romain
Welcome to the :grafana: community @romain!
I answered a similar post here that you might find helpful.
Hello @melori.arellano,
I was able to upgrade Grafana to 8.5 and use the Value Mapping feature. Now I end up with a table cleaned up without any ID which is great.
Now, how can I do some post-processing on the result after value mapping?
For example, using Value Mapping, I end up with:
Port
Cloud Service
Cloud Service
I want to display a pie chart showing: 1 Port and 2 Cloud Services.
I tried to use Value Mapping and Select the Pie Chart but Grafana doesn’t seem to use the values post-value mapping but uses the original values.
See my value mapping settings:
And the result (which works great!):
Here I want to represent the number of “Cloud Router” and “Cloud Router BGP Settings” for example.
Thanks for your help,
Romain
What is the source of this data?
A database? A rest api? A file?
@yosiasz it is an elastic search database and the data are logs coming from GrayLogs (Elasticsearch)
Elasticsearch has json document data. Please post one sample json document data.
Here is the sample data:
    "state": "Done",
    "series": [
        "refId": "A",
        "fields": [
            "config": {
              "filterable": true
            "name": "timestamp",
            "type": "time",
            "values": [
              "2022-09-27 19:38:29.192",
              "2022-09-27 19:35:52.336",
              "2022-09-27 18:58:57.881",
              "2022-09-27 18:58:13.518",
              "2022-09-27 18:27:45.865",
              "2022-09-27 18:26:40.607",
              "2022-09-27 18:25:02.515",
              "2022-09-27 17:21:12.877",
              "2022-09-27 17:16:25.294",
              "2022-09-27 17:15:07.978",
              "2022-09-27 17:15:07.701",
              "2022-09-27 17:15:06.953",
              "2022-09-27 17:15:06.716",
              "2022-09-27 17:11:41.377",
              "2022-09-27 17:07:11.396",
              "2022-09-27 17:07:10.986",
              "2022-09-27 17:07:10.204",
              "2022-09-27 17:07:10.014",
              "2022-09-27 16:50:48.385",
              "2022-09-27 16:43:40.523",
              "2022-09-27 16:43:40.240",
              "2022-09-27 16:43:39.305",
              "2022-09-27 16:43:39.121",
              "2022-09-27 16:42:12.329",
              "2022-09-27 16:42:12.055",
              "2022-09-27 16:42:11.044",
              "2022-09-27 16:42:10.774",
              "2022-09-27 16:40:40.566",
              "2022-09-27 16:40:40.354",
              "2022-09-27 16:38:58.466",
              "2022-09-27 16:38:58.274"
            "state": null
            "config": {
              "filterable": true
            "name": "path",
            "type": "string",
            "values": [
              "/v2/services/cloud-routers/PF-L3-CUST-1234567/connections/aws",
              "/v2/services/cloud-routers/PF-L3-CUST-1234567",
              "/v2/services/cloud-routers/PF-L3-CUST-1234567/connections/PF-L3-CON-1234567",
              "/v2/bgp-settings/a12334a1-a12b-1234-c12d-abc123456cdf/prefixes",
              "/v2/services/cloud-routers/PF-L3-CUST-1234567/connections/PF-L3-CON-1234567/bgp/a12334a1-a12b-1234-c12d-abc123456cdf",
              "/v2/services/cloud-routers/PF-L3-CUST-1234567/connections",
            "state": null
        "first": [
        "parsers": {},
        "length": 31
    "annotations": [],
    "request": {
      "app": "explore",
      "dashboardId": 0,
      "timezone": "browser",
      "startTime": 1664308073982,
      "interval": "30s",
      "intervalMs": 30000,
      "panelId": "1234",
      "targets": [
          "refId": "A",
          "key": "1234",
          "query": "request_source: \"search\"\n",
          "alias": "",
          "metrics": [
              "id": "1",
              "type": "raw_data",
              "settings": {
                "size": "500"
          "bucketAggs": [],
          "timeField": "timestamp",
          "datasource": {
            "type": "elasticsearch",
            "uid": "ABCD"
      "range": {
        "from": "2022-09-27T07:47:53.980Z",
        "to": "2022-09-27T19:47:53.980Z",
        "raw": {
          "from": "now-12h",
          "to": "now"
      "requestId": "explore_left",
      "rangeRaw": {
        "from": "now-12h",
        "to": "now"
      "scopedVars": {
        "__interval": {
          "text": "30s",
          "value": "30s"
        "__interval_ms": {
          "text": 30000,
          "value": 30000
      "maxDataPoints": 1261,
      "liveStreaming": false,
      "endTime": 1664308075444
    "timeRange": {
      "raw": {
        "from": "now-12h",
        "to": "now"
    "timings": {
      "dataProcessingTime": 0.29999999701976776
    "graphFrames": [],
    "tableFrames": [
        "refId": "A",
        "fields": [
            "config": {
              "filterable": true
            "type": "time",
            "values": [
            "state": null
            "config": {
              "filterable": true
            "name": "_id",
            "type": "string",
            "values": [
              "f65c4ad4-3e9b-123456",
              "98d7dcd1-3e9b-123456",
              "70ecb152-3e96-123456",
              "567be4d3-3e96-123456",
              "151d9140-3e92-123456",
              "ee37d593-3e91-123456",
              "b3c0cb14-3e91-123456",
              "c91bcc76-3e88-123456",
              "1db244a5-3e88-123456",
              "ef9c2c13-3e87-123456",
              "ef72d224-3e87-123456",
              "ef003a39-3e87-123456",
              "eede0c30-3e87-123456",
              "74789501-3e87-123456",
              "d38df8bf-3e86-123456",
              "d34dbb6a-3e86-123456",
              "d2d7a100-3e86-123456",
              "d2b9dfd0-3e86-123456",
              "89a0b7d1-3e84-123456",
              "8a9a4f89-3e83-123456",
              "8a6f9607-3e83-123456",
              "89dfd920-3e83-123456",
              "89c37780-3e83-123456",
              "56096e93-3e83-123456",
              "55dfc685-3e83-123456",
              "554449d1-3e83-123456",
              "551bb332-3e83-123456",
              "1f5893d4-3e83-123456",
              "1f3665d1-3e83-123456",
              "e27d0c83-3e82-123456",
              "e25dc4ac-3e82-123456"
            "state": null
            "config": {
              "filterable": true
            "name": "path",
            "type": "string",
            "values": [
            "state": null
        "first": [
        "parsers": {},
        "length": 31
    "logsFrames": [],
    "traceFrames": [],
    "nodeGraphFrames": [],
    "graphResult": null,
    "tableResult": {
      "refId": "A",
      "fields": [
          "config": {
            "filterable": true
          "type": "time",
          "values": [
          "state": null
          "config": {
            "filterable": true
          "name": "_id",
          "type": "string",
          "values": [
          "state": null
          "config": {
            "filterable": true
          "name": "path",
          "type": "string",
          "values": [
          "state": null
      "first": [
      "parsers": {},
      "length": 31
    "logsResult": null
The goal is to show a Pie Chart with the 34 Cloud Routers (cloud-routers) and 4 BGP Settings (bgp-settings).
