11.4.0-79146 -
Group the results by removing the k8s names -
First step is transform the results by removing the extra information in pod_names. For e.g. if the name is home-cart-75657f7676-54t2v, I would like to extract home-cart. To achieve this I am using transformations [1]+.[a-z]+.[a-z]+.*$ -
What happened?
It is replacing the column name instead of the actual data -
[2]+.[a-z]+.[a-z]+.*$ -
No -
No
As far as I know Value Mappings are the last step that are applied, so the transformations will be applied first. Would Format string transformation with substring mode work? If not, what datasource are you using? Maybe you’ll be able to do so on the datasource side?
The format string with substring will not work because of the variable size of fields
home-cart-werewrgwe-ewergu
home-cart-api-egerreg-egewr
home-orderview-erggwer-ergwer
home-orderview-api-ergerww-eerwgwer
I was able to get the results using below query
avg(label_replace(kubernetes_io:container_memory_request_utilization{…}, “app_name”, “$1”, “pod_name”, “(?<role_name>[a-z0-9]+(?:-[a-z0-9]+)*?)(?:-([a-f0-9]{8,10}))?-([a-z0-9]+)”)) by (app_name) * 100
Thanks to all who helped me in figuring this out.
