I’d like to visualize different stats of pods in Deployments and StatefulSets in my Kubernetes cluster, but group by pod-name-prefix. I am aware that I could assign labels to my pods and then use a solution like outlined here. For the sake of understanding Grafana better, I would still like to know if there is a solution to this particular problem. What I tried and failed to do is rename the pod names with the regex field rename transformation to remove the random stuff at the end, and then somehow merge the fields with the same name. Even if this is not the most elegant way to do this, I would like to know if this is possible at all.
As an example, I have attached a screenshot of a plot showing the pod restarts. Here you can see multiple grafana-k8s-monitoring-alloy pods and I would like to merge those into one plot line. I am aware that this will only work for Deployments and StatefulSets with 1 replica.
Thanks a lot!
Alexander
- Grafana v11.3.0-75420 (d1dc595692) in Grafana Cloud
- Regex-rename fields, then merge fields with the same name.
- Ideally via some transformation.
What happened?
- I do not know which transformation to use. Multiple fields with the same name are shown in my visualization.
- A transformation exists that merges fields with the same name, so I get one continuous time series for each unique field name.
