I call an api and as response I get json data, now this json contains csv data that I need to convert into a table. I am not able to come up with a solution to this.
Example of data:
“jsonrpc”: “2.0”,
“result”: [
“itemid”: “59832”,
“value”: “col1 | col2 | col3 | col4\n entry1 | entry2 | entry 3 | entry4”
Here I need to visualise the data in “value” as a table.
Welcome
Who wrote this api ? Is it a commercial product?
That is a very odd json reply cause its really not proper json nor is it csv. Its pipe delimited.
Yes, I agree. But as of now, I will have to work with the given data only.
Please suggest something with the available data.
not a valid json but cleaned it up here please verify. So which data point(s) do you want to plot? entry ?
"jsonrpc": "2.0",
"result": [
"itemid": "59832",
"value": "col1 | col2 | col3 | col4\n entry1 | entry2 | entry 3 | entry4"
I want to plot result[0].value i.e. the value field of the first item in the result array.
Which part of that pipe delimited data do you want to plot on a chart and what kind of chart? What have you tried so far?
I want to convert the complete data mentioned above into a table.
look at using jsonata with infinity plugin
$data := $.result.value; $newline := $split($data, '\n');
$split($newline[0], '|');
$col := $split($newline[0], '|').{
$entry := $split($newline[1], '|').{
try it out here for test purposes
https://try.jsonata.org/
Thanks a lot. I was able to extract the data into a table using jsonata.
I want to keep the first row as the table headers, how can I achieve this?
@yosiasz The issue is not fully resolved yet. Please have a look at the list line of my last comment.
you will need to sort that out in your jsonata query so that it produces a key value pair
"col1" : "entry1"
