Would there be a way to set the number of decimals displayed for the value on a tooltip?
Currently, it looks as if it rounds the value and shows an integer in the tooltip.
A snipet from my Postgres data source table: (plotting only ‘time’ and ‘value’)
time | ntime | value | value32 | visible
2023-12-12 21:58:55 | 45272.9159143519 | 102.3125 | 102-10 | f
2023-12-12 21:58:55 | 45272.9159143519 | 101.90625 | 101-29 | f
2023-12-12 21:58:55 | 45272.9159143519 | 101.91015625 | 101-29 1/8 | f
2023-12-12 21:57:52 | 45272.9151851852 | 101.90625 | 101-29 | f
2023-12-12 21:57:52 | 45272.9151851852 | 101.90234375 | 101-28 7/8 | f
What Grafana version and what operating system are you using? 9.2.3 / windows 10
What are you trying to achieve? unrounded display of value in tooltop
How are you trying to achieve it? i’m not
What happened? nothing different
What did you expect to happen? nothing, couldn’t find the option
Time series | Grafana documentation
