What Grafana version and what operating system are you using? Using grafana on Chrome on Windows PC
What are you trying to achieve? Hi, I’m new to Grafana. I’m using OSIsoft-PI as data source. My data values range from -1 to 5. I would like to calculate the total time the values are >1 and display the total for a given period of time, day, month as a stat panel.
How are you trying to achieve it? Trying to filter values greater than 1 and counting the time they are on. Then add all the time together to display on the stat panel. On the other hand I also have a state timeline with the same data source and the tooltip shows the exact duration it was <1.This is what I want but unable to do on a stat panel to show a total time(see below) Is there any way to extract info from the tooltip throughout the day and display a total in a stat panel?
What happened?
Can you copy/paste the configuration(s) that you are having problems with? No
