Grafana v10.4.1 (d3ce857c0e) OSS on Debian Bookworm (installed through .deb) -
I would like to hide the tooltip in a candlestick chart, which has been introduced in Candlestick: Add tooltip options by adela-almasan · Pull Request #81307 · grafana/grafana · GitHub . -
By editing the panel and switching “Tooltip mode” to “Hidden”. -
What happened?
The whole config section “Tooltip” is not displayed at all, but several other options, which are not even applicable to candlecharts:
Having the tooltip options available in v10.4.1. -
It also happens for a completely new dashboard and panel. Nothing fancy/hacky involved. -
No errors in the logs or even the browser’s debugger (besides a few unrelated deprecation warnings). -
Nope. Couldn’t find anything, probably because the feature is still quite new.
What i did so far without making a difference:
- Clearing browser caches
- Copy&pasting the tooltip option from a timeseries chart using the JSON model
- Installing the .deb package again, after having verified its SHA256 checksum
- Trying to block the tooltip through uBlock Origin (worked, but broke a few other things as well)
- Checked /public/app/plugins/panel/candlestick/CandlestickPanel.tsx, whether the changes from Candlestick: Add tooltip options by adela-almasan · Pull Request #81307 · grafana/grafana · GitHub are actually there (they are)
The next attempt would be to reinstall from scratch on a virtual machine (upgraded from v8.x recently), but before i would like to ask, if i’m missing anything obvious.
Thanks!
