I’m trying to do a load test with client using https. To be closer to real clients I’d like to see what is the impact of having tls session resumption used. However, I don’t see any way to configure that with k6 : noConnectionReuse and noVUConnectionReuse seems to only create completely new sessions with a full handshake.
Regards,
Arnaud
Hi @duarnad,
I needed to read up on it somewhat, but unfortunately don’t have time to completely understand everything.
The tl;dr is that this is not supported(at least not in full), because:
- we need to change the http/tls code in k6 to cache the session ticket … which we apparently don’t, but I managed to get something working with 1 line … it just will probably require more for an actual PR.
- golang (the language that k6 is written in) apparently doesn’t support session ID resumption
And because we are still pushing PR 1007 out, I propose you make an issue to implement this in the future
Thank you ! Ok. In the mean time I have also looked at the go level and I was surprised they don’t support session ids. At least for tls 1.2 session tickets are often disabled server side for security reasons. I’ll create an issue as you suggest : this would help to have a more realistic load as no keep alive without session resumptions quickly kills the performance.
I had not seen this PR and this is really promising !
Regards,
Arnaud
