TLS client certificate with PostgreSQL
Trying to create dashboard connected to Google Cloud SQL running postgres, with TLS authentication.
I’ve generated server and client certificates, but unable to upload them (what seems to be possible with Graphite and ElasticSearch for example)
Is it possible? Am I missing something?
Thanks
Upload them where can you please clarify more ?
Hello.
I’ve also tried configuring PostgreSQL plugin with Google Cloud SQL and had encountered same issue: To connect securely with GCS from public IP I should somehow provide Grafana with client certificates but I don’t see any way to do so.
Has anyone found any way to define/upload a certificate to be used or contacted Grafana directly about this?
