Connecting to Postgres over SSL to an RDS DB
I’ve signed up with Grafana Cloud, and am currently trying to connect it to my Postgres RDS DB using SSL.
I’ve opened up the Grafana Cloud IPs using this link: List of source IPs to allowlist | Grafana Cloud documentation
It seems to connect and there is no timeout so I presume I’m sorted on the IP front, but when I execute a query I get a message:
“db query error: stat /var/lib/grafana/tls/{filenameRemoveJustIncaseItIsSecret}generatedTLSCerts/client.key: no such file or directory”
In the connection settings in Grafana, I’ve configured the host, database, password and:
TLS/SSL Mode: verify-ca
TLS/SSL Method: Certificate Content
TLS/SSL Client Certificate: Copied in the pem file content from here: Using SSL/TLS to encrypt a connection to a DB instance - Amazon Relational Database Service
TLS/SSL Client Key: I’ve left this blank
I assume my error is down to not putting in a value for TLS/SSL Client Key, but does anyone know where I get this from?
Thanks for your help.
Hi @mwiseman ! If you haven’t already done so, please open a ticket from your account portal so the team can take a closer look at that error!
