Hi all,
can someone brieflily explain me how the Timing Option Works?
i tried to set the Repeat interval 52 Week.
i want my allert just one time to Friring and one is firing he don’t have to be avaluated anymore.
Hi all,
Hi! I’m afraid that’s not how Grafana works. Grafana will evaluate each alert rules once per Interval seconds. You set this when creating the rule. If you would like to not receive repeated notifications for the same alert you should set a large Repeat interval and also disable grouping in your notification policy.
