Windows, grafana-enterprise-8.1.5.windows-amd64.msi -
A graphical plot from values in DB. -
SELECT TOP(1000) dateadd(s, convert(bigint, [Timestamp]- 13*3600), convert(datetime,‘1-1-1970 00:00:00’)) as ‘time’,
convert(float,Cal0_DesignValue) as Cal0_DesignValue, convert(float,Cal1_DesignValue) as Cal1_DesignValue
FROM combined
ORDER BY time desc -
What happened?
Time is in descending order. I see in Table or Graphical form the values are all OK, but Graphical form the time on the left side is much later than the time on the right side of plot. -
I need the plot to have the time on the left side to be earlier than the time on the right side. -
No Errors, but just the plot is wrong, because the time on the left side is later.
Are you sure that this is not just the tooltip hovering over different datapoints?
Can you use the inspect drawer to show what your raw unformatted data looks like?
Solved, thanks, because it is Order BY time desc.
