Hi Team,
I am using grafana version of 8.4.4. I am getting below error with Microsoft SQL Server as data source in stat panel. I have requirement where I want to represent values in ascending order. I am using this query to fetch records from DB.
SELECT $__timeGroup(moment,‘5m’) as time,
avg(res_is_available) ,
res_name
FROM
audit_health
GROUP BY
$__timeGroup(moment,‘5m’),
res_name
ORDER BY
avg(res_is_available) asc,
time
I am able to get data from DB if I am removing the avg(res_is_available) field from order by clause. But requirement is to display values in ascending order with avg(res_is_available) field. Can anyone please help in this?
Take out the order by Time and change the Grafana setting under the Query “Format as” to Table
You only need the Time Series if you want a mini graph inside the Stat Panel
Hope this helps!
Hi @T_GrumpyEngineer,
I already tried that approach but I am getting below output through that query which I don’t want. I want to show all res_name in graph.
Could you elaborate more if I am doing anything wrong?
Ok I’m doing someting similar just excuse the hidden sub-select
Sometimes I force Grafana to see the metric and value same as you’re doing for time
And then for the Grafana format settings on the side
Think you were calculating Average on SQL and then Average on Grafana too
Hopefully this is it
Thanks for your reply. I want to represent the same way like first get average from sql and then represent the avg through grafana. My only concern is that I want to do order by it’s value using same panel and format of timeseries. Is there any way to do it?
SELECT res_name
,AVG( res_is_available )
FROM audit_health
WHERE moment > DATEADD(MINUTE,-5,moment)
GROUP BY res_name
ORDER BY AVG( res_is_available ) DESC -- or ASC instead
Grafana settings to Format as Table, Value Options . Show > All Values
To get the 6 orignal results unchanged by Grafana, otherwise you’re Averaging an Average from SQL and Grafana thinks you want 1 result back
Thank you so much for your help. I managed to get that result back using this approach.
Also recommend you try this out by using a numeric value pointing to the column #. Calling a SQL function in ORDER BY might be a performance issue especially if you do not have an index on it then your dashboard does not lag.
SELECT res_name
FROM audit_health
GROUP BY res_name
ORDER BY 2 DESC
