Using Grafana opensource 10.2
I have a dashboard that defaults its time period from now-2d to now.
a few of my charts use Last* instance metric (ex CPU % dial)
There are two problems around the end time from the time picker.
if the zoom out is clicked, the end time becomes a future date. The chart shows no data.
This makes sense because the future date hasnt reported data. -
my database is fed data every two minutes from multiple sources. Therefore “now” from where grafana is connected for the db is = this exact moment (minute/second) but the data has not yet arrived. Refreshing the chart in 2 minutes brings the data in and everything charts properly.
Some solutions could be: (are any of these possible?)
A. block future dates on the time picker? so its always now or eariler - never have a future date.
B. force “now” to be the last known data available date? max date from db
C. is there a way to configure the charts / query to always pull the last found data which might be bit earlier than the “now” value.
Thanks,
Joe
