v9.4.3 MySQL -
I want to use $__timeGroup macro and convert_tz function in the same query to change display date to local time (UTC → Europe/Paris) -
Using the query below :
SELECT
convert_tz(min(ts),‘Europe/Paris’,‘UTC’) as time,
TagName as metric,
count(TagValue) /(($__interval_ms / 1000) / 600) as value
FROM
conso
WHERE $__timeFilter(ts)
Group by $__timeGroup(ts, $interval,NULL),metric
order by time asc -
What happened?
When i group by day, the display date in the tooltip is “DD-MM-YYYY 02:00:00” instead of “DD-MM-YYYY 00:00:00”. It doesn’t take into account the convert_tz function. After investigation, it seems that it’s the “NULL” in the $__timeGroup macro that’s causing the problem. When i write $__timeGroup(ts, $interval), i have the right date format. -
Date format taking account my local timezone (“DD-MM-YYYY 00:00:00”)
Do you have any idea ? Thank you
