Grafana v9.2.2 at Grafana Cloud.
MongoDB data source for Grafana v1.4.9
- What are you trying to achieve?
I’m trying to make my stats dashboards being adapatable to the globally specified time range.
- How are you trying to achieve it?
I’m using __timeFrom and __timeTo macros provided by MongoDB plugin. Here’s my query:
my_db.mycollection.find({"datetime": {$gt: $__timeFrom, $lt: $__timeTo}})
datetime is a field in ISODate format.
- What happened?
The above-mentioned query results in the following error: “error parsing find args - error decoding key 0.datetime: invalid JSON input. Position: 48. Character: $”.
If I inspect the query, it looks as follows:
my_db.mycollection.find({"datetime": {$gt: {"$date": "2019-07-16T02:57:47Z"}, $lt: {"$date": "2021-05-03T00:00:00Z"}}})
I expected the dashboard to display data which datetime is between $__timeFrom and $__timeTo.
- Did you follow any online instructions? If so, what is the URL?
My query is very similar to the examplr in MongoDB plugin documentation.
