TimeFilter in panel name, values on graphs
I`ve got 2 questions.
First, how i can put ‘timefilter’ variable in panel/dashboard title. I want to do something like "Data in last $__timeFilter days. "
Second, i want to present one graph with one line in percentage, but if i hover on data point i want to see this value (%) and second non-relative value.
Thanks
I am also trying to get the selected time range displayed in a panel title.
I’ve read https://grafana.com/docs/grafana/latest/reference/templating/ which
says near the top “You can use variables in metric queries and in panel
titles.” and then at the bottom lists built-in variables:
$__interval
$__timeFilter
So, I’ve tried using __interval and [[__interval]] in my panel titles, and I get literally that text: "__interval" or “[[__interval]]” - the variable name
doesn’t get de-referenced to its value.
What am I doing wrong? I want to get the text of the time range selected
using the standard dashboard drop-down list (top right) to be displayed as
part of the panel title.
If I create my own variable and have a drop-down selector for it at the top
left of the dashboard, then I can get exactly what I want - something such as
[[Timescale]] gets de-referenced to “7 days” in the panel title.
But defining my own time range variable when there’s already a standard built-
in system facility for this seems somewhat unnecessary.
Thanks in advance,
Antony.
Here are my workaround for this topic.
I think you can’t use al kind of variables on a dashboard surface.
My solution is to define a new dashboard variable.
Here is an example how to display the “$__interval” in the panel header.
Now you can use the new variable in the panel.
2019-12-17_13h01_08
Jo
Hi.
Thanks for the suggestions (it’s an interesting workaround), but it doesn’t
work for me.
As soon as I enter “select __interval" or "select __interval_ms/1000” into
the Query box, I get the error message:
Template variables could not be initialized: error parsing query: missing
parameter: __interval
Then, where I use my variable name in the panel title I get “undefined”.
Any ideas?
Antony.
Hi Antony,
I think it depents on the selected Data source. In my case with MySQL and MS SQL it works flowless.
“select $__interval/1000”
Hi Jo
Its an old post, I am trying to do exactly your solution here only with $__timeFilter, interval works perfectly like you show but I cannot get time filter to work, do you have any suggestions for this?
Hi, in Grafana 8 I did the same ì. I create a variable as query: INSERT ‘$__interval’ but it always show me 1s
hi @donatod
$__interval is different from $__timeFilter (timefilter being the variable that this post is looking to show in the title, and i assume you too are looking to show, ie if you graph is the past 7d , via the time picker, i assume you want “7d” to show in your panels title
so when you see 1s for $__interval , that is correct (as the interval in your graph/panel is 1sec, look under “Query Options” drop down, when in the edit panel page.
that said, i dont know the answer to: what is the variable to use in Panel Title so that it shows the current, live updated, time-picker’s “TimeFrame” (ie the 7d or 7day in my example above).
I know i have had this working in my some of my prior panel’s titles, but i cant seem to get it working again (or im using the wrong variable , also). according to the docs, it should be variable:
$__timeFilter
but that does not resolve to anythnig for me on grafana v9.02 (with a graphite DS and using the Time-series panel type).
sorry i have no answer for you (hopefully someone else does)
(LOVE GRAFANA)
