I am using Azure Managed Grafana -
I would like to use the current time range, from the time drop down, as part of a table description. When the user change the time range, I would also like to change the table title or description. -
I have been playing with all kind of variables like $__from and $__to -
What happened?
Either I get the dates in UNIX timeframe or I dont get anything else. -
I would like the result to be for example “Last 30 minutes” or “Last 6 hours”.
Thanks!
