- 12.2.0 (Problem did not exist with 11.4.1)
- Charting a process value with time series information
- The Time Series graphic
What happened?
- The time series and other charts do not properly display the data after updating the locally hosted Grafana containers from version 11.4.1 to 12.2.0. The lines are now compressed at the bottom as if there’s a huge top margin.
- A standard time series chart displayed… filling the entire area.
"datasource": { "type": "datasource", "uid": "-- Mixed --" }, "description": "", "fieldConfig": { "defaults": { "color": { "mode": "palette-classic" }, "custom": { "axisBorderShow": false, "axisCenteredZero": false, "axisColorMode": "text", "axisLabel": "", "axisPlacement": "auto", "axisSoftMax": 100, "barAlignment": 0, "barWidthFactor": 0.6, "drawStyle": "line", "fillOpacity": 0, "gradientMode": "none", "hideFrom": { "legend": false, "tooltip": false, "viz": false }, "insertNulls": 900000, "lineInterpolation": "linear", "lineStyle": { "fill": "solid" }, "lineWidth": 1, "pointSize": 5, "scaleDistribution": { "type": "linear" }, "showPoints": "auto", "showValues": false, "spanNulls": false, "stacking": { "group": "A", "mode": "none" }, "thresholdsStyle": { "mode": "off" } }, "mappings": \[\], "min": 0, "thresholds": { "mode": "absolute", "steps": \[ { "color": "green", "value": 0 }, { "color": "red", "value": 80 } \] } }, "overrides": \[ { "matcher": { "id": "byName", "options": "aggregate_value" }, "properties": \[\] } \] }, "gridPos": { "h": 7, "w": 12, "x": 0, "y": 1 }, "id": 1, "maxDataPoints": 3840, "options": { "legend": { "calcs": \[\], "displayMode": "list", "placement": "bottom", "showLegend": true }, "tooltip": { "hideZeros": false, "mode": "single", "sort": "none" } }, "pluginVersion": "12.2.0", "targets": \[ { "datasource": { "type": "influxdb", "uid": "snsr-influx-influxql" }, "query": "REDACTED", "rawQuery": true, "refId": "Methane_PPM_Rev4", "resultFormat": "table" }, { "datasource": { "type": "influxdb", "uid": "snsr-influx-influxql" }, "groupBy": \[ { "params": \[ "$\__interval" \], "type": "time" }, { "params": \[ "null" \], "type": "fill" } \], "hide": false, "orderByTime": "ASC", "policy": "default", "query": "REDACTED", "rawQuery": true, "refId": "Methane_PPM_Rev6", "resultFormat": "table", "select": \[ \[ { "params": \[ "value" \], "type": "field" }, { "params": \[\], "type": "mean" } \] \], "tags": \[\] }, { "datasource": { "type": "grafana-postgresql-datasource", "uid": "snsr-postgres-grafana" }, "editorMode": "code", "format": "table", "hide": false, "rawQuery": true, "rawSql": "REDACTED", "refId": "Metadata", "sql": { "columns": \[ { "parameters": \[\], "type": "function" } \], "groupBy": \[ { "property": { "type": "string" }, "type": "groupBy" } \], "limit": 50 } } \], "title": "WTF Mate", "transformations": \[ { "id": "merge", "options": {} }, { "id": "filterByValue", "options": { "filters": \[ { "config": { "id": "equal", "options": { "value": "Median" } }, "fieldName": "aggregate_type" } \], "match": "all", "type": "include" } }, { "id": "filterFieldsByName", "options": { "include": { "names": \[ "Time", " ", "device_name" \] } } }, { "id": "prepareTimeSeries", "options": { "format": "multi" } } \], "type": "timeseries"}
- No
- No… I updated the
