Grafana 11.1 TimeSeries not working after migration
after updating Grafana from 10.4 to 11.1, my TimeSeries panel stopped showing data. The query execution shows that data is pulled, however I don’t see it on the graph.
Review the queries used in your TimeSeries panels. Grafana 11.1 might have introduced changes in query syntax or behavior. Ensure that your queries are correctly formatted and compatible with the new version.
Examine the queries that your TimeSeries panels are using. There may have been modifications to query syntax or behavior with Grafana 11.1. Make sure your queries are compatible with the latest version and formatted correctly.
