v 9.3.2 running in Docker -
I record analog temperature values and digital switching states (e.g. of pumps). I would like to display these simultaneously in a graph to make the interdependencies visible.
However, these values should not overlap (completely). Ideally, digital values are displayed below the analog values. -
My first try looks like this:
These are the database queries
from(bucket: "iobdata")
|> filter(fn: (r) => r["_measurement"] == "modbus.0.holdingRegisters.6_TempPufferO")
|> filter(fn: (r) => r["_field"] == "value")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "last")
and
|> filter(fn: (r) => r["_measurement"] == "modbus.0.coils.22_AnfBrenner")
|> yield(name: "last")
What happened?
The analog values are displayed as expected. The digital values overlap the analog values at full height.
Here, a user had created a solution for “stacked” digital assets with a workaround.
Grafana true/false seit Update nicht mehr möglich
I would like to have something like this for an analog and a digital value. -
no
