Time Range Dependent Panel
I want to make panels created in grafana to be dependent on time range filter which is on the left corner of the grafana.I am using mysql datasource.How can I achieve it ?
Hi @skumari1308 ,
Take a look at this post: Grafana custom time range for custom Graph Panel
There is one possible solution for the problem, hope it helps!
